raelga
Dec 04, 2020Tutor
SRR60 random reboots
I have a pair of SRR60 / SRK60, when it works, works awesomely but the router randomly reboots itself during the day, several times, different hours. I'm running the last firmware Router Firmware...
- Dec 07, 2020
Thanks schumaku and JohnC_V for the help.
After some further testing, I decided to return the device. I conneted it to an UPS and replaced the powersupply for a more powerfull one (12V/6A), but it kept rebooting. I needed something stable, not something that needs debug and troubleshooting out of the box, that's why I went for the Pro series.
JohnC_V
Dec 04, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues with your Orbi Pro system. May you be able to capture the debug logs after the issue occurred? Just in case the router is working fine, don't capture the logs. Capture it only when the issue occurred.
- Log into Orbi Pro by https://<ip address of Orbi Pro>/debug.htm
- Start capture when the issue occurred.
- Wait at least 5 mins to record everything in the debug log file system.
- Save the debug logs and send them via pm for review.
I'm looking forward to your reply.
John
NETGEAR Community Team
raelga
Dec 04, 2020Tutor
Thanks JohnC_V for the quick reply, I started to capture right now. Let's wait for the router to eventually reboot itself and then I will send back to you the logs.
I have the satellite just in front of me, so I can detect the reboot instantly. The satelitte goes Purple, internet goes down for about 3 minutes and when I log back to the admin page, the router uptime is about 1-2 minutes.
- raelgaDec 04, 2020Tutor
Saldy, it didn't took long for the reboot to happen again.
