LlamaLarry
Feb 16, 2021Luminary
SRS60 Dual WAN/Failover?
I live in an area with no wired broadband, but have been getting by with an LB2120 (Bridge Mode) feeding my SRS60+2xSRC60 for my office space. Tomorrow my Starlink dish should arrive and I intend to...
- Feb 16, 2021
The SRS60 does not have a dual WAN/failover capability.
DaneA
NETGEAR Community Team
schumaku
Feb 16, 2021Guru - Experienced User
LlamaLarry the LB2120 however has a wonderful feature named broadband failover - you link the new satellite Dish Internet connection Ethernet cable through the LB2120 and from there to the SRS60 WAN/Internet port. If the dish internet is down, the LB2120 LTE will pick up the backup.
Consult the fine documentation FMI -> https://www.netgear.com/support/product/LB2120.aspx#docs
