BretD
May 11, 2021Administrator
SXK30 Orbi Pro WiFi 6 Mini System: Business Mesh WiFi System for WFH
Work-from-Home Security and Performance In an era where business professionals and students are working and learning from home, network congestion and security are real issues. The Or...
BIG9MM
May 13, 2021Apprentice
Nice, we will buy just need to know if it will work with the SXK80?
JohnD333
May 14, 2021Apprentice
These kits have a base (router) plus 1 satellite (sat) or base (router) plus 2 sats.
Sounds like you already have the base (router). If so, you only need more SXS80 units. Those are the sat units. I have not seen 2-packs or 3-packs of those. If you already own the SXK80 base router, pricing is such that it would make little sense to buy a new kit.
Beware Orbi-Pro WiFi 6 SXK80 is not compatible with netgear’s Orbi WiFi-6 for residential (RBK852) nor Netgear’s earlier WiFi Pro models.
- BIG9MMMay 14, 2021Apprentice
"These kits have a base (router) plus 1 satellite (sat) or base (router) plus 2 sats."
I needed to know if it will work with the SXS80 as I know I can just buy the 1 satellite on amazon. :]
Yes. I have the one SXS80 and one SXR80.
Thanks for the info!
Beware Orbi-Pro WiFi 6 SXK80 is not compatible with netgear’s Orbi WiFi-6 for residential (RBK852) nor Netgear’s earlier WiFi Pro models.- DaneAMay 24, 2021NETGEAR Employee Retired
The SXR30 and SXS30 do not support and will not pair with Orbi Pro WiFi 6 router (SXK80) or satellite (SXS80).
DaneA
NETGEAR Community Team
