crpntr's avatar
crpntr
Follower
Oct 18, 2021
SXK30 satellites will not stay synced
Hello,
I have an SXK30B3 set with additional satellite, that I can not seem to keep the satellites functional on for more than a day.
They do not drop out, but connected devices lose all connectivity. I have tested the firewall wide open for the firewall, switches are trunked to it with all VLANs available, default VLAN is set to WLAN 1 as mentioned in other issues, as well as trunk on the LAN ports on the device, but it still seems to persist.
Does anyone have any further ideas before I return these and try something else? I love the throughput I get when they're up, so it would be great if I could get them up and running.
Any help is appreciated, thanks!
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    crpntr
    Welcome to the community!
    How are the satellites connected to the router? Wired or wireless backhaul?
    Also, does the issue happen only on wireless or wired devices connected to the satellite or router?
    There are a couple of things we can try, kindly check the following:
    1. Perform a reset on the satellites only and resync them.
    2. Check if the router and satellites are updated to the latest firmware (latest FW is v3.2.33.110) by going to ADVANCED > Administration > Firmware Update
    JeraldM
    NETGEAR Community Team
ProSupport for Business
