MetalGeek
Jul 07, 2023Aspirant
SXK50 Access point and Vlan setup
 Has anyone setup an Orbi Pro in Access Point mode, enable the built in VLANs and controlled the VLANS with a smart with and router?  My reasons for this are covered in my future use case:     I have ...
MetalGeek
To clarify, my router would be a router/firewall like pfsense or comparable product.
BasuKhodanapur
Jul 10, 2023Apprentice
Hi MetalGeek
We have used for setting up Airplay, chromecast and Printer it works well with mDNS.
Yes using Obri Pro as router mode. Router mode help to setup mDNS, with this feature you can set a rule so all VLAN30 services are shared to VLAN 1 and IOT(Vlan30) services from vlan1 or Vlan20 etc.
Thanks,
Basavaraj
