MetalGeek
Jul 07, 2023Aspirant
SXK50 Access point and Vlan setup
Has anyone setup an Orbi Pro in Access Point mode, enable the built in VLANs and controlled the VLANS with a smart with and router? My reasons for this are covered in my future use case: I have ...
schumaku
Jul 10, 2023Guru - Experienced User
MetalGeek wrote:
It supports access point mode but does it support the VLANs as well?
Of course, that's the intention. However, some hours ago it came to my ears that under some conditions the DHCP does not pass to some tagged VLAN.
MetalGeek
Jul 10, 2023Aspirant
schumaku wrote:
MetalGeek wrote:It supports access point mode but does it support the VLANs as well?
Can you provide details or a link to this info? This is exactly the kind of info I'm looking for.
- schumakuJul 10, 2023Guru - Experienced User
There was a post a few hours ago by secdoc -> here
Completely untested on my side, as I don't own a Orbi Pro 6 test sample.
- MetalGeekJul 10, 2023Aspirant
Thanks, that mirrors what I've read. I saw the original post but was hoping newer firmware had addressed the issue. Doesn't look like it based on that latest post.
- BasuKhodanapurJul 11, 2023Apprentice
In AP mode mDNS feature is grayed out meaning not applicable, So we have to make it work using upper router .
Where as you can define vlans in AP mode, But should have dhcp server running in upper router.
Thanks,
Basavaran
