MetalGeek
Jul 07, 2023Aspirant
SXK50 Access point and Vlan setup
Has anyone setup an Orbi Pro in Access Point mode, enable the built in VLANs and controlled the VLANS with a smart with and router? My reasons for this are covered in my future use case: I have ...
schumaku
Jul 10, 2023Guru - Experienced User
There was a post a few hours ago by secdoc -> here
Completely untested on my side, as I don't own a Orbi Pro 6 test sample.
MetalGeek
Jul 10, 2023Aspirant
Thanks, that mirrors what I've read. I saw the original post but was hoping newer firmware had addressed the issue. Doesn't look like it based on that latest post.
- BasuKhodanapurJul 11, 2023Apprentice
In AP mode mDNS feature is grayed out meaning not applicable, So we have to make it work using upper router .
Where as you can define vlans in AP mode, But should have dhcp server running in upper router.
Thanks,
Basavaran
- schumakuJul 11, 2023Guru - Experienced User
Dear Basavaran,
As I said before: More than strange Netgear does support mDNS on the Insight managed WAX then. This explanation does not make any sense to me. hnagaraju please.
-Kurt
- BruceGuoJul 12, 2023NETGEAR Expert
WAX and Orbi Pro are different product line and have different implementation.
Theoretically, in AP mode, it needs upper router help forward multicast across VLANs.
Or, use Orbi Pro in router mode.
