LarryNATL
Dec 31, 2020Follower
SXK80 - DHCP Question - Support for multiple DHCP assignments for the same device on different VLAN?
Hello, I have a question on the capabilities of the Orbi SXK80 product. I'm working on my network design, and I have a question that I am hoping someone can answer (I have read the manual on-lin...
JohnD333
Feb 04, 2021Apprentice
Regarding
"About this scenario, the MacBook Pro will not receive the IP reservation in each different VLAN.
DaneA"
While it appears that you can make ra eservation range and assignments for each LAN (SSID), if you make one for the MBPro on LAN1, then another on LAN2, then another in LAN3, or only two of the above, only the last assignment will be valid and the MBPro will conncet to that reserved/assigned IP address regardless of which SSID/LAN the MBPro connects with.
It is interesting that with an IP reserved&assigned to LAN1(admin) (___.____.10.__) "APPLY", and then IP reserved&assigned to LAN3 (IoT) (___.___.30.__), "APPLY", that when MBPro is wirelessly connected to LAN1 it gets that reserve IP from LAN3 (___.___.30.__), but can see and connect to all LAN1 devices. But as stated above, MBPro will not receive the IP reservation in each different VLAN.
schumaku
Feb 05, 2021Guru - Experienced User
JohnD333 wrote:It is interesting that with an IP reserved&assigned to LAN1(admin) (___.____.10.__) "APPLY", and then IP reserved&assigned to LAN3 (IoT) (___.___.30.__), "APPLY", that when MBPro is wirelessly connected to LAN1 it gets that reserve IP from LAN3 (___.___.30.__), but can see and connect to all LAN1 devices. But as stated above, MBPro will not receive the IP reservation in each different VLAN.
This reads like a major bug requiring a fix.
Dos this still apply to the v3.2.1.102 firmware (current as of writing)?
