ringleader215's avatar
Mar 10, 2021
SXK80 and SRS60 compatible??
SXK80 and SRS60 compatible?? are able to use the SXK80 (two pack) Orbi pro or SXK80B3 (three pack) with SRS60 Orbi pro wall mount satellite?? They are bothe wifi 6 and Pro?
  • MrJoshW's avatar
    Mar 10, 2021
    Hello,
    No, both devices are not compatible as they are different wireless technologies. You would need to purchase additional SXS80 satellites with your current SXR80 configuration.
ProSupport for Business
