ringleader215
Mar 10, 2021Aspirant
SXK80 and SRS60 compatible??
SXK80 and SRS60 compatible?? are able to use the SXK80 (two pack) Orbi pro or SXK80B3 (three pack) with SRS60 Orbi pro wall mount satellite?? They are bothe wifi 6 and Pro?
- Mar 10, 2021
Hello,
No, both devices are not compatible as they are different wireless technologies. You would need to purchase additional SXS80 satellites with your current SXR80 configuration.
ringleader215
I'm not sure I understand... or if in asked the question incorrectly. I'm interested in purchasing a SXK80. Is possible to use a SRS60 a satellite?
Property is 6000sqft... on 2acres.
My current RBK50 [RBK44] Doesn't cut it. Still signal drops in the house. Thinking if upgrading to pro version.
DaneA
Mar 11, 2021NETGEAR Employee Retired
Welcome to the community! :)
The SXK80 belongs to the Orbi Pro WiFi 6 System while the SRS60 belongs to the Orbi Pro WiFi 5 System. In conclusion, the SRS60 will not work with the SXK80.
DaneA
NETGEAR Community Team
- ringleader215Mar 11, 2021AspirantGotcha
Very much appreciated
