TheGrumpyGent's avatar
Dec 20, 2021
SXK80 Networking 101 Question with the Orbi Pro
HI everyone, slightly embarrassed asking this but its been a while setting up VLANS.  I have a couple devices I want to have on a specific VLAN that I plan to wire up (IoT in the Orbi Pro).  Its goin...
  • JohnC_V's avatar
    Dec 31, 2021
    Hi TheGrumpyGent,
    You can change the VLAN profile on each port by going to ADVANCED > Advanced Setup > VLAN / Bridge Settings. From there, you can change either the router or the satellite ports.
    John
    NETGEAR Community Team
ProSupport for Business
