JBQuinnforRCRC
Nov 13, 2023Aspirant
SXR30 AX 1800
We have an SXR30 (AX1800) router. I had remote management activated and the allowable IP addresses defined. This worked for about 6 months. This has suddenly stopped working and the remote access opt...
schumaku
Nov 14, 2023Guru - Experienced User
Discussed and explained already here.
JBQuinnforRCRC
We have an SXR30 (AX1800) router. I had remote management activated and the allowable IP addresses defined. This worked for about 6 months. This has suddenly stopped working and the remote access option has disappeared from the menu path. Has Netgear eliminated this capability?
- schumakuNov 13, 2023Guru - Experienced User
Probably yes - to much risk just challenging a password without any intrusion prevention or 2FA.
- michaelkenwardNov 13, 2023Guru - Experienced User
Not sure what you set up, but this may help:
Why is the Remote Management feature being removed from NETGEAR routers? | Answer | NETGEAR Support
and
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
