iNeeDzv
Feb 28, 2022Aspirant
SXR30 disconnessioni notturne
Salve, ho un problema, ho acquistato da circa un mese il modello SXR30 con due satelliti, fino a qualche giorno fa tutto è andato bene. Il problema è che da qualche giorno tutte le notti alle 2:00 (se...
Feb 28, 2022Guru - Experienced User
In inglese per favore
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro (SR and SX Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
iNeeDzv
Ok sorry, English:
Hi, I have a problem, I bought the SXR30 model with two satellites for about a month, until a few days ago everything went well. The problem is that for a few days every night at 2:00 AM (always at the same time), they disconnect, the front LED is not on and a restart is enough to bring everything back to normal, so I am forced to restart every morning. How can I do?
Thank you
Thank you
- FURRYe38Feb 28, 2022Guru - Experienced User
What FW version is loaded on the system.
The front LED should remain OFF when normally working.What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
