TampaBaySailor
Aug 27, 2024Guide
SXR30 problem with ERR_SSL_KEY_USAGE_INCOMPATIBLE
Trying to add SXS30 satellites to my SXR80 system, one SXS80 now. Can't get wifi networks to carry over after connecting. Want to set the SXR30 the same as the SXR80, to configure the SXS30's, but ...
Aug 28, 2024Guru - Experienced User
Please try the released FW since those older links don't seem to work anymore.
Want to set the SXR30 the same as the SXR80, to configure the SXS30's, but can't get past the ERR_SSL_KEY_USAGE_INCOMPATIBLE error on Chrome & Edge.
I had this problem when they made the security change with the SXR80, but got past it with the registry key addition, but can't find anything that works with the SXR30.
