aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade.
Anyone seen this ?
Bryan
How is the SXS connected to the SXR? directly to the back of the SXR or is there a patch panel or LAN switch in between?
- aafa760Aspirant
SXS30 is connected via switch.
Should it be plugged into SXR30 directly? if so then Lan configuration would need to be default for that port correct ?
Bryan
