vsharma1410
Jun 20, 2023Aspirant
SXR50 & SXS50 sync issues since firmware V4.3.1.106
Good day, Setup - Router + 3 Satellites Wired Connections to all satellites using CAT6 100% Copper Cables. 4 VLANS in use. ISSUE: The system is working, wifi and network is stable for the...
BasuKhodanapur
Jun 20, 2023Apprentice
Hi vsharma1410 ,
Thanks for contacting Netgear Community forum, surely will help you with network issue.
Can we get some more information
1. Setup is insigth managed or standalone mode ?
2. What was the last working firmware version ?
3. Network topology to understand switch and satellites connection
4. Please DM me contact details, we can have call to understand more on the issue
Thanks,
Basu Khodanpur
vsharma1410
Jun 21, 2023Aspirant
Sure.
1. I generally use insight but have also logged in through the routers page for troubleshooting and setting up VLAN's and ports.
2. It would have been Firmware Version 4.3.0.140 which was the firmware immediately before the current installed firmware.
3. Ignore the arrow heads, just doing a quick diagram for you to see.
