vsharma1410
Jun 20, 2023Aspirant
SXR50 & SXS50 sync issues since firmware V4.3.1.106
Good day, Setup - Router + 3 Satellites Wired Connections to all satellites using CAT6 100% Copper Cables. 4 VLANS in use. ISSUE: The system is working, wifi and network is stable for the...
NickvandenBroek
Jul 26, 2023Aspirant
Same here, not able to connect to the SXS. Please come up with a solution or at least a work around, thanks!
