vsharma1410
Jun 20, 2023Aspirant
SXR50 & SXS50 sync issues since firmware V4.3.1.106
Good day, Setup - Router + 3 Satellites Wired Connections to all satellites using CAT6 100% Copper Cables. 4 VLANS in use. ISSUE: The system is working, wifi and network is stable for the...
NickvandenBroek
Jul 26, 2023Aspirant
Same here, not able to connect to the SXS. Please come up with a solution or at least a work around, thanks!
BasuKhodanapur
Jul 27, 2023Apprentice
Hi vsharma1410 ,
We need debug logs to identify the root cause, Please help with the logs .Will try to resolve the case.
I have updated the steps to capture the debug logs.
Thanks,
Basavaraj
- BasuKhodanapurJul 31, 2023Apprentice
Please share the debug logs if able to capture . It will help us to fix sync issue.
Please let me know if any support required.
Thanks,
Basavaraj
