vsharma1410
Jun 20, 2023Aspirant
SXR50 & SXS50 sync issues since firmware V4.3.1.106
Good day, Setup - Router + 3 Satellites Wired Connections to all satellites using CAT6 100% Copper Cables. 4 VLANS in use. ISSUE: The system is working, wifi and network is stable for the...
NickvandenBroek
Jul 26, 2023Aspirant
Same here, not able to connect to the SXS. Please come up with a solution or at least a work around, thanks!
NickvandenBroek
Jul 31, 2023Aspirant
I fixed it, unfortunatly I don't know how exactly.
What I did was resetting the SXR50 and just started the configuration all over again. The SXS50's connected automatically and now I can see them in Netgear Insight.
The only issue I now have is my DHCP reservations, is there someway to import them from a backup or generally import them from any type; csv or whatever?
Thanks!
- BasuKhodanapurJul 31, 2023Apprentice
Good to hear that, everything is working smooth.
Sure let me check configuration backup with DHCP reservations , Will come back to you.
Thanks,
Basavaraj
