net_zero
Oct 13, 2022Aspirant
SXR80 - Unable to configure a stable mesh
I have a new SXR80 and two SXS80 satellites I'm trying to use to cover a moderately large home installation. ~3500 sq. ft. in the main house which is arranged in a long rectangular layout, so close t...
timecode
Oct 19, 2022Guide
As another user with the same setup I can suggest the following as it took me some time to get it working:
1: remove any and all traces of Insights - buggy mess - use a browser - your sanity will thank me.
2: start with just one satellite first get it stable on this. Then add second satellite.
3: Don't use any VLANs just yet - I have been working with Netgear mods on this one - there is a confirmed issue with Satellite sync with 2 or more units - the standard single vlan is fine.
Should mention I use this in AP mode as the router functions are far too limited.
net_zero
Oct 20, 2022Aspirant
Thank you for the response.
I am using the devices in AP mode, and as I actually purchased two pairs of (1) SXR80 and (1) SXS80 (4 units total) I have been using the two SXR80's hardwired as access points, and for the last week or so since I first posted, the network has been rock solid.
It's good to know about the VLAN bug - that sounds like what was causing a great deal of my issues - as adding any satellite to this configuration wreaks havoc. That said, these will be going back to the retailer as I've simply spent too much time troubleshooting, and they are unable to operate as advertised - to provide me with a mixed wired and wireless mesh network with multiple VLAN's.
