jcharnet
Jan 18, 2024Guide
SXR80- Guest Wifi - Access to Printer in Main Wifi
Hello everyone,
I have my main wifi configured in wireless1, and I also have the guest wifi set up. Is it possible to allow guest to access a specific device on the main wifi? For example a printer? I'd like to give guests the ability to print, is there any "magic" routing that we can do to make that happen?
Thanks a lot,
Joao.
Just for one device ... probably not, to my knowledge, Netgear does still not want to understand why we asked for allow adding granular firewall rules a looong time ago already. The convenience approach would be to enable mDNS allow spanning over multiple VLANs - inheriting more risks than typically intended, see for example here
- BrianLNETGEAR Moderator
Hi jcharnet,
You can also check the product SW manual for more information about mDNS and make sure your ORBI network is up to date.
Kind regards,
