mcnahum
Aug 13, 2021Apprentice
SXR80 . Devices don't get IP (DHCP on Pi-hole) since 3.2.6.102
I have multiple devices who have a really painful issue and this since I upgrade to 3.2.6.102. They don't get IP address ... they got connected ( I think to the SXS80) to the wifi ... but no IP are ...
Aug 13, 2021Guru - Experienced User
Your pi-hole is running dhcp?
are you using a vlan for any of your ports/devices?
What vlan is the pi-hole on?
- mcnahumAug 15, 2021Apprentice
Yes Pi-hole is running DHCP.
I'm using VLAN and Pi-hole only manage my "main" LAN.
I have 2 other VLAN for guest and tempoary devices
