mcnahum
Aug 13, 2021Apprentice
SXR80 . Devices don't get IP (DHCP on Pi-hole) since 3.2.6.102
I have multiple devices who have a really painful issue and this since I upgrade to 3.2.6.102. They don't get IP address ... they got connected ( I think to the SXS80) to the wifi ... but no IP are ...
mcnahum
Aug 15, 2021Apprentice
Yes Pi-hole is running DHCP.
I'm using VLAN and Pi-hole only manage my "main" LAN.
I have 2 other VLAN for guest and tempoary devices
Aug 15, 2021Guru - Experienced User
The devices having issues, are they on the vlan with the pihole?
- mcnahumAug 16, 2021Apprentice
Yes devices who have issues are on the VLAN with the pi-hole. and I'm 95% sure they are connected to the SXS80 when they have the issue.
- plemansAug 16, 2021Guru - Experienced User
what are you using for the Vlan in terms of client isolation/network isolation? (advanced---advanced setup---vlan/bridge settings)
Since the ri-pi is controlling dhcp, if its isolated from the other devices, maybe thats causing them to not get IP addresses
- mcnahumAug 17, 2021Apprentice
no that VLAN is open to other.
I have 50 devices on that VLAN and except 2 iphones all the other devices are getting an IP without any issue.
