IgnacioHR
Dec 04, 2022Follower
SXR80 Still not supporting Roaming
Hi,
I purchased a set of 4 of this Orbi SXR80 but they still do not properly support roaming.
In the configuration there is a "checkbox" to enable Fast Roaming but it does NOTHING!
I finally managed to use wireshark to try to find support for 802.11r but it is not there so there is definitively no support for fact roaming.
As you can see on this page: https://mac-wifi.com/how-to-verify-whether-802-11k-and-11r-are-enabled-via-a-capture/ the Orbi SXR80 is missing the "Tag: Mobility Domain" so there is no support for it.
No RepliesBe the first to reply
