Dmsjr2
Dec 31, 2025Aspirant
SXS80 firmware update
Had or I pro mesh for 3 or 4 years sxr30 router and two Sxs30 satellites. All working fine and firmware up to date. Wanted to extend the mesh to garage - couldn’t find another sxs30 anywhere but have...
- Jan 01, 2026
Update: managed to access sxs80 webpage and do manual update ( safari on mac) and all working fine now
Dec 31, 2025Guru - Experienced User
You can try factory resetting it. Prior to re-syncing it with the system, try connecting to it and manually updating the firmware that route. But you might not want to do that. The reason why, is that the SXR30 (if thats your base router), wasn't compatible with that satellite .
https://kb.netgear.com/000065558/Which-Orbi-Pro-routers-and-satellites-are-compatible
So if you have it working, it might be better to just be happy it works. I'd be worried upgrading the firmware would break that. If you have the SXR80 router, then I wouldn't be worried.
- Dmsjr2Jan 01, 2026Aspirant
