oliversimpson
Mar 19, 2024Guide
SXS80 wired backhaul
Hi Everyone. I have an Orbi Pro Satellite system — and I am considering wired backhaul for them. They're not very far apart — however, I'm keen to increase the speeds nonetheless. My router is se...
- Mar 26, 2024
No.
Mar 20, 2024Guru - Experienced User
Any SXS needs to be connected behind the SXR if ethernet connected for proper connection with the Orbi router:
There can be a LAN switch in the middle.
- oliversimpsonMar 20, 2024Guide
Thanks.
Is it possible to LAG the two ports from each satellite to achieve the speeds I want while still having the satellites physically connected?
- FURRYe38Mar 26, 2024Guru - Experienced User
No.
