Vintners's avatar
Vintners
Apprentice
Oct 03, 2019
Sync Enabled or Disabled?
Hi Guys, Looking for some advice? Do I enable the sync of the satellites or disable them? They were all disabled when I logged in but I don't know what to think! I have 8 satellites (yes, it all wo...
  • DaneA's avatar
    Oct 06, 2019
    Vintners,
    After your satellite syncs with your Orbi Pro router, the satellite’s Sync button is disabled for security reasons. If you press the Sync button and the satellite’s LED bar pulses magenta, this LED behavior indicates that the Sync button is disabled.
    To learn about the Sync button, kindly read page 23 of the SRC60 user manual here.
    If your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
