Kristopher
Jan 24, 2020Star
Unable to connect to admin console page V2.5.0.108
Hello, After updating to V2.5.0.108 I can no longer connect to admin web URL https://192.168.1.1/index.htm. It says 500 - Internal Server Error. Is the certificate bad on the server? htt...
- Feb 04, 2020
Hi all,
Please update FW to 2.5.1.106 which fix block and "Unable to connect to admin console page" issue.
schumaku
Jan 27, 2020Guru - Experienced User
Kris,
This is not a Orbi change - something is borked on your device. Both the Web UI, the direct remote access, and the App does make use of the internal Web server in some way.
To start with the unliked process: Just like the Netgear support will tell you - a factory reset might be required.
Christian_R please ensure the customer service does get in touch with Kristopher , thank you!
-Kurt
evan2
Feb 04, 2020NETGEAR Expert
Hi all,
