JorgeV
Apr 01, 2022Aspirant
Unable to connect to SRS60 Orbi Pro
I used a RSS60 system with a main router and two satellites for two years, 2019-2020, just after the pandemic. Then we left the office for several months and suddenly my Orbi system stop working. I didn't have the time to further investigate the problem, until now.
I'm not being able to setup the system again: I tried using the Orbi App, nothing; I tried resetting the main device, since I don't need the old settings anymore, but I can't connect with it... I can't see the default wifi network the device is supposed to generate and if I connect directly with an ethernet cable I don't get a proper IP direction form the router DNS so I'm unable to access to the control interface.
After resetting, I got a long solid red light in the power led, followed by a blinking red and then a solid green light.
I read that a blinking red light means a corrupted firmware. Could it be the problem? I can't check which firmware I have since I can't access the device. Any suggestions? Is there a way to force a firmware reset/upgrade using a trick via an ethernet cable?
Thanks for your help, in advance.
- schumakuGuru - Experienced UserTry the ubiquitous tftp recovery
https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-on-Microsoft-Windows
https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt
https://kb.netgear.com/000064624/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-on-Apple-macOS
SRS60 might be the correct model.- JorgeVAspirant
Thank you very much for the reply and the suggestion, schumaku. After contacting Netgear support, they determined that my router was dead but still within warranty, so I applied for a replacement. I have a new router and now everything is working fine. I didn't have the opportunity to try your solution.
Thanks anyway!
