taurus1961
Nov 26, 2024Aspirant
Wired backhaul
I have a problem with my Orbi router and satellites. The Router is configured as a accesspoint and i have 2 satellites. My network is rather simple. On the groundfloor there is a modem/router. A 8 po...
taurus1961
Nov 29, 2024Aspirant
Reroute the wiring as you suggest. I was hopeful because it looks that this is the right way. Unfortunately there is no difference. It works in that way that's for sure. The router(configured as an AP) on the ground floor is now directly connected to the satellite on the first floor and the satellite on the second floor is directly connected to the satellite on the first floor. So it's a daisy chained configuration.Switches for the rest of all equipment in the house are connected to the rest of the available lan ports of the AP's. Everything works.
Actually i wasn't sure how to bring the internet signal from my Modem/Router to the first AP. Is that on the WAN port or a LAN port? Works both and i see no difference.
Another thing is when i search the internet how to setup a backhaul on a orbi i get this site: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System. In the right colomn "his article applies to" a can't find my SRR router and my SRS satellites. Could it be that a configuration like i want isn't possible at all?
I was aware of my misconfiguration when i installed a RBR750 system at my kid's place. But when i configured it the right way a collumn "Backhaul status good". Not at my site unfortunately.
Nov 29, 2024Guru - Experienced User
So you have a Orbi Pro system? SRR and SRS? Which model?
Though not same system, I would think the pro line would work is same manor.
WAN is required to be used in back of any Orbi router while in AP or router mode.
- taurus1961Nov 29, 2024Aspirant
SRR60 and SRS60
- FURRYe38Dec 20, 2024Guru - Experienced User
- taurus1961Dec 20, 2024Aspirant
No,
I still don't have a column in the webinterface which tells me the status of the wired backhaul. Yes the satellites are present in the interface as a device but devices in a range less then 2 meters from a satellite has a very poor connection which results very often in a disconnection. For a doorbell this is not good
