trvlncwl's avatar
Feb 25, 2022
MR60 no longer runs scans
Armor shows last scan done 12-01-2022. Attempts to scan manually all fail.
  • glad it worked!
    If you mark it solved,it might help others as well as keeping others from trying to still fix it :)
  • plemans's avatar
    What firmware version are you on?
    Have you tried a reboot?
    Or factory reset?
    • trvlncwl's avatar
      trvlncwl
      Tutor
      Firmware version is 1.1.6.122. I have tried reboot a few times and have not tried factory reset.
      • plemans's avatar
        I would try the factory reset. Looks like that firmware was released at the start of december. that'd coincide with your last scan. Sometimes firmware updates cause enough changes a factory reset helps.
