user11111's avatar
user11111
Something Went Wrong, Try Again Error Messgae
When trying to access the orbi app on my andriod, not a problem, but when I try to access the Armor Security Tab through the app, it opens but doesnt refresh and error messgae (Something Went Wrong, Try Again) keeps popping up.  Dashboard shows I have vulnerablities, but when I click on it, it says I dont have any.  If I access router directly to view armor, it doesnt let me access.  Cant do anything.  How do you fix?
  • I am having the same issue today. Reboot my RBK852 Router + 1 Satellite but no help! Uninstall and reinstall the Netgear Orbi APP on my Android phone did not help either. My phone support is out of 90 days period. Did you have any luck? Thanks.
    • user11111's avatar
      user11111
      No luck so far. I tried all the same and nothing. Not sure why support for their software subscription of their supported software should run out. 90 days for product support is rather worthless as well. If I can't get it to work, surely won't be renewing anytime soon. Waste of money to purchase security software that doesn't seem to work
      • Christian_R's avatar
        Christian_R
        NETGEAR Employee Retired
        Hello,
        Thanks for sharing your experience. May you provide the following info for us to look into this further.
        Router Model:
        Router Firmware Version:
        Thanks,
        Christian
  • Same problem.
    Router rax50, firmware last available at July 2021.
    No way to solve with reinstall app, factory reset router
