kristib
Jun 03, 2020Tutor
Circle Blocking Known Sites
My household uses the free Circle program. Around a month or two ago, Circle started randomly blocking sites we've visiting many times before and/or sites that do not fit any sort of blocked category (my bank site today, school sites that my kids have used before, etc.). Most of the time, you can refresh about 15 times and/or clear the browser cache, exit and re-open and then it will suddenly work. This is a HUGE hassle. I updated the router firmware which did not seem to help. Does anyone know what's causing this issue? Does Circle get updated when the router firmware updates or is it the same version that was installed when we bought the router a couple of years ago?
I wish there was better support for Circle. If I go to the Circle website and indicate it's on my router, it brings me to Netgear and there doesn't really seem to be much support from Netgear.
Thanks for any help!
- Christian_RNETGEAR Employee Retired
Hello kristib,
Welcome to the community! May you provide us with the router model and firmware version your router is currently on.
Christian
- ptweav75Initiate
My circle filters/blocks most websites too. Under history, I do not see the sites to "allow" them. I have to set filter to "none" or disable circle to use internet. Firmware V2.3.5.12_1.0.8
- kristibTutor
Thanks. Model: R7000/AC1900. Firmware Version V1.0.11.100_10.2.100.
- bwilfordTutorI have the same issue. It has occurred off and on and usually clears with a router reboot. However I’ve rebooted a few times in the last week and can’t get rid of the problem, other than turning Circle off. I’ve also found if I try the same site several times it may work eventually. By no means valid solutions, but hopefully the extra info can help someone fix the issue.
- bwilfordTutorDoes anyone ever address issues posted here or is this just for customers to try helping each other since expired support gives no alternative.
- ptweav75InitiateThey have been working on my issue since June with no luck. They sent a replacement Orbi but it did not resolve. I get a call from the Philippines every couple of weeks telling me they are still working on it, but have no timeline on resolution. Beyond frustrating.
- bwilfordTutorCircle has been highly disappointing anyway and the have what little capability there was broken is pretty pathetic. Thins needs fixed now and massive improvements to monitoring and notifications like tomorrow.
