Goosey_Gander's avatar
Aug 30, 2019
Circle limits the speed of gig router by more than half.
I have fiber coming to my house so my internet speeds run 950Mbps download at the modem, into the router and to my computer via wifi UNTIL I enable Circle Parental controls. My speeds immediately sink to 250 Mbps! I disable parental controls and it goes right back up to 950Mbps. I turn on parental controls and it immediately falls to 2/3rds of what it was before. This is the second of these routers that I have bought because Netgear support told me the first new one was bad and it shouldn’t limit it like that. Well, the second one does the same thing. It is a software problem. Why bother putting parental controls on an expensive gig router if you can’t use it?!
