Bcole's avatar
Bcole
Bug genie 3.1.12 app will not screen rotate to landscape
The genie 3.1.12 android will not screen rotate from portrait to landscape
  • schumaku's avatar
    schumaku
    ...standard Netgear App problem, applies, to Genie, Up!, ... and Arlo (the latest not on a phone, OK on a Tablet).
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi all,
    The bugs have been reported and engineering is already aware. Please try uninstalling and re-installing the app to check if some issues will be resolved. Also, please keep an eye on updates for the app for the fixes.
    Dexter
    Community Team
    • Bcole's avatar
      Bcole
      Thank you Dexter.
      By chance do you know if I will lose my device names and device type setting if I uninstall and Reinstall?
      Second is there a release notes or a way to subscribe to a defect so when a correction is released people can be notified or a way to scan through a defects listing based on app version and platform.  Hopefully one or both of those might reduce bug repostings.
      Thank you,
      Billy
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi Bcole,
        Yes, you will lose the custom device names.
        Yes, release notes are usually indicated on the app description portion on the Playstore/Appstore.
        Dexter
        Community Team
