daveke
Jan 17, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 09, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
nekotruong
Oct 17, 2016Tutor
Hello DexterJB
I think you dont get what i mean. Thge problem is I can't login to my router. Everytime i try to loging to my rounter then i got this
"You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
For more information about how to access routerlogin.net, visit Router login page cannot be displayed "
or
"NETGEAR router is not found or is not supported. Also make sure the device is not connected to the geat network of the router, and no IPv6 is enabled."
agian i did try to connected me laptop with my router by cable and i did check me IPv6. about how to change my passwork of my router i do know how.
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi nekotruong,
1. Have you tried using your router's IP address and access it via a browser?
2. On which device do you have the NETGEAR Genie program/app installed?
3. Have you tried using another device (Android, iOS, another computer)?
4. Please try uninstalling and reinstalling the app/program then reboot the router.
Dexter
Community Team
- agent86Oct 20, 2016Star
Dexter,
Let's not get off track. nekotruong is describing an issue with the Genie App. Yes. There may be other ways to access the router, but mere "access" to the router is not the resolution sought here. Instead, we are reporting a problem with the Genie App that arose within the last two to three months.
The App is basicially preventing users access to supported routers access using the Genie App. As a consequence, functionality is lost. The issue here: we want the Genie App fixed.
Next, your suggested resolutions have already been tried - I have fully explained the efforts expended in my original post. After performing your suggestions, the Genie App still reports the same error message (i.e. the suggested solutions do not make any difference; thus, the suggests are not the resolution).
I am replying to your latest post because it is a diversion from the original issue that the Genie App is broken. I need to start using functionality for which I purchased the router (i.e. parental controls) and the Genie App plays an integral part in setting up functionality that is otherwise not accessible through other means of access. So, please stay focused on the original issue: problems with the Genie App.
Thank you,
agent86
- jwilson484Jan 08, 2017Initiate
I have been experiencing the same issues with my Netgear WNDR3700v3. I have done everything mentioned in these posts and I still have the same issue when trying to access Parental Controls using the Genie or accessing Router Settings via the Genie. I am unable to access Parental Controls and it says, "Checking router firmware. We are making sure you have the firmware that supports Live Parental Controls. And then is says, You don't appear to be connected to the internet. Please connect to the internet and try again. But I am connected to the internet, as I am sending this reply now, via the internet. The network map is up to date and correct with all the current devices conncected being shown. I am also unable to access the "Router Settings". I have tried putting the IP in manually and keep getting the following: Login failed. The router response timed out. I assumed it may be an issue with Windows 10 but I see that Windows 7 users are having the same problem and I also have the same issues with my Android devices and the Genie download for those devices. It used to work but it doesn't anymore for some reason. Back a year or so ago I used the Genie without any problem. But recently, I decided to use the Parental Controls to control what my 16 year old is able to see and when he is able to access the internet. But all I have had now is problems with the Genie.
- DexterJBJan 09, 2017NETGEAR Moderator
Hi jwilson484,
Dexter
Community Team
- hotshotjoeJan 21, 2017Initiate
I tried all the above and it still time outs using admin as username and password as password.
- DexterJBJan 22, 2017NETGEAR Moderator
Hi hotshotjoe,
1. What is the model number and firmware version of your router? Please refer to the link below for the list of supported devices for NETGEAR Genie.
http://kb.netgear.com/app/answers/detail/a_id/24686
2. Please try using another device (Android, iOS, another computer).
3. Try uninstalling and re-installing the program/app.
Dexter
Community Team
- DexterJBJan 25, 2017NETGEAR Moderator
Hi hotshotjoe,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team - LaurelCJan 26, 2017Initiate
I started having a problem with the Genie app yesterday. I need to monitor the traffic on my router and it seems that the only way to do it is through the Genie app router settings section. Yesterday, the Genie app started crashing so I reinstalled it after downloading it from the internet. At that point, I couldn't log in to the router setting from the Genie app. I then reset the router. That did not help. I still can't log in (yes, I know the password was reset to "password", but I logged in to the router via a web browser and changed the password there). But the problem is that I need the traffic meter!
The error I get is "Login failed! Please check to see if this computer is connected to the NETGEAR router." And, I am using the correct password and user name!
LaurelC
I seem to have fixed the problem. I redownloaded the Genie app from the Netgear website. The site I had downloaded it from yesterday was CNET. Maybe the CNET version is not the latest. I can now see the traffic meter again.
LaurelC
- MVolkerFeb 11, 2017Aspirant
My router login problem is identical to what immediately preceeds this posting. I can log into my Netgear router via 192.168.1.1 wireless connection. Parental controls do not provide an option to connect to OpenDNS. Click on Parental Controls and it says "Checking router firmware." Genie tells me "You don't appear to be connected to the Internet. Please connct to the Internet through your NETGEAR router and try again." Pressing the button "Try again" returns the same result. When browsing to the router the Parental Controls status shows "Not Enabled." For some reason, it appears that Genie will not browse out to find the router, even though I can browse the Internet just fine. The Genie version I loaded comes from the Netgear website. The following recommended solution on this Community website did not work:
1. Install the latest version of NETGEAR Genie. You may use the download link below.
http://netgear.com/home/discover/apps/genie.aspx
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers from the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6bEVUbmxtUTY0MW8/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie programWhat next steps should I try?
- wallygMar 12, 2017Aspirant
i have uninstalled and reinstalled geine app. i have reset router. i have also factory reset. firmware is the latest. running windows 10 pro
any help much appreciated
thank you
ac 3200 nighthawk x6 mod r8000
first time using this foum. router is ac 3200 nighthawk x6 mod r8000
- wallygMar 16, 2017Aspirant
the model is ac 3200 x6 nighthawk r8000. i have upgraded to latest router firmware and updated to latest genie software. i have reset router to fatory setting.
still unable to log into router via genie software. now same issue on windows 7 pc. any help appreciated
- Gogo6969Apr 14, 2017Initiate
Same problem here!
Everything is updated to the latest versions/firmware.
The latest update of Genie stopped working somehow.
It now shows "Login failed. The router response timed out" when cklicking on "Router Settings" or "Parental Controls" or "ReadyShare".
This is especially strange because I still can login from this computer via browser and I also see the "Network Map" in the Genie app.
I'm pretty sure that there is a problem with the latest version of the app or the recent firmware update of the router!
If you don't know yet, my provider recently told me that they raised security protection because the new government is now trying to spy on everyone and everything we do. This is no joke...
- baddad828Apr 14, 2017Initiate
same issue. Nighthawk X6 R8000. Also tried uninstalling and reinstalling Genie. Still get same result....timeout when i try to log in admin and 'you don't appear to be connected to the internet' message.
- vickyraoApr 16, 2017Star
same here. still having the issues. done all i could on the router and setup and re installed on iphone and android and still the same. cannot login to my router from the genie app. but using a web browser has no issues.
Netgear, please help to resolve this.
- DexterJBApr 18, 2017NETGEAR Moderator
Hi all,
I have done my own tests using the latest firmware and app versions for all platforms (Windows, iOS, Android) and did not encounter any issue. If re-installing the app does not fix the issue, please try resetting the router back to factory defaults.
Dexter
Community Team
- vickyraoApr 19, 2017Star
Just because you are not able to reproduce does not mean there isnt any issue. Could you please investigate further on this matter urgently?
Reset router is not an option when we have many configurations already done. I am not willing to do that. Unless export settings and import will work. Can you confirm on that?
- Lh75Apr 19, 2017Tutor
So I'm also having the same issue as everyone.
I can access the Router admin page via the browser and enable parental controls. But the Genie (Windows) App will not connect to the router. When you click on Router Settings, you get the error "Login failed: The router response timed out". I also get the same issue on the Phone via a wireless connection "Login Failed... The NETGEAR Router was not found or is not supported..." which is actually crap. I run a Netgear Nighthawk R8000 running the latest Firmware (V1.0.3.36_1.1.25). I'm also running the latest Genie version 2.4.38 as was freshly installed today.
Interesting point though was I rebooted the router,, As soon as it was active, I tried the Genie login again which was successful but none of the settings was able to be downloaded, then got a timeout. Stopped and restarted Genie and get the same "Login Failed...." message as above.
Again, and is present in many threads, I get an additional issue in the Parental Controls section of Genie:
"Were making sure you have firmware that supports Live Parental Controls.
You don't appear to be connected to the Internet. Please connect to the Internet through your NETGEAR router and try again" - which is odd considering the Internet Status is "Good".
I am able to enable Parental Controls via the Admin screen via a browser and I am able to login to OpenDNS and manipulate accounts so I know that all passwords and accounts are working.
There is clearly an issue with the Genie app, at least on a Windows PC.. either that or there is some issue in the lastest firmware that stops external admin access once parental controls is enabled?
So whats all the hassle about? Well you need to be able to configure Genie to be able to use Bypass accounts to implement different levels of filtering. So there is a real reason needing for this issue to be resolved...
Factory Defaulted the Router settings and started again.
Initially the Genie Windows App and the Android App both working, then all the same errors started coming back. Only thing configured on the router is Internet connection settings and new Wireless Key. nothing else has changed.
Starting to look more like a Netgear Router issue instead of a Genie issue..
- jcallenjApr 20, 2017Aspirant
Signed up just to share...
For me, rolling back the firmware seems to have fixed it, at least so far.
Background:
Just bought the thing, was working great, decided to let it "upgrade" firmware to have the listed security fixes, and then started seeing problems:
- Windows Genie (on the Router Settings, Parental Controls, and ReadySHARE tabs):
- Stopped logging into the router, and would just spin its spinner a long time instead.
- Started showing this error: "NETGEAR router is not found or is not supported. Also make sure the device is not connected to the guest network of the router, and no IPv6 is enabled." (like halfway down here)
- Rarely would login, but then show this error: "The operation timed out." (like so)
- Browser "Genie" (RouterLogin.net or 192.168.1.1)
- Would hang and eventually time out on first attempt to connect.
- Would prompt for log in if I tried again immediately after first time out.
- Would work fine for a minute or two but then hang again during use every minute or two, after which I could refresh and log in again as in Step 2 (if I was quick enough), and so on...
Starting from a clue here, I decided to give it a shot (rolling back the firmware). As mentioned at the start, everything seems good again now. Browser functions were better right away, while the Windows app still seemed unsure for a few minutes but then has been good since.
My guess is the fix for one of the security issues (which apparently made it into many firmware updates for many models) introduced some kind of authentication/timing problem which the browser interface isn't handling well and the app can't seem to overcome much at all.
Windows 10 Pro / genie 2.4.38
Chrome 57.0.2987.133 (64-bit)
NETGEAR WNR2000v5
Firmware: now 1.0.0.34 after 1.0.0.42
