Spiffy2Man's avatar
Spiffy2Man
Circle safe search not working
When I first setup circle on my tablet safe search was working well. After I added all my devices and changed so of the other configuration options I tested everything again. Now safe search doesn't work and YouTube searches that were working no longer work. In fact, I can't seem to get amazon prime or YouTube to work at all. So circle is completely useless, as it isn't filtering unwanted items, and is filtering items that I do want. Any suggestions?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Spiffy2Man,
    1. What is the firmware version of the R7000?
    2. What is the operating system (Android or iOS) of the device that you used to configure the Circle settings?
    3. Does the issue (wrong filtering) persist on all your devices?
    4. Have you tried resetting the router?
    Dexter
    Community Team
    • Spiffy2Man's avatar
      Spiffy2Man
      Sorry, but I have been to busy to try again. Just updated to the latest firmware, still not working.
      Firmware is V1.0.9.18_1.2.27.
      Android marshmallow.
      Yes. The "safe search" function does not work correctly on any device.
      Yes, I have restarted the router multiple times.
      • topwebs's avatar
        topwebs
        Same things are happening with us. At first Safe Search set Google Safe Search on all devices. Recently, that has stopped working on all devices. Then, even more recently, the Ad Blocking filter is no longer working. As we are paying Circle for their premium features, I am quite upset that there seems to be nowhere to get support or even report issues.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Spiffy2Man,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
