JC21's avatar
JC21
Disney Circle stops working frequently on R7000
Disney Circle Premium stops working frequently on R7000. The only way to fix it, that I've found, is to restart the router. My family is not happy, as they are often blocked from the internet.
I setup my Circle environment originally with the free version, and took my time over a week or more to ensure that I'd setup all the profiles of my family correctly, with their assigned devices. Once I was happy that they were all configured correctly, I then purchased the Premium option to gain the extra features that I was so longing for! I left it a few days before turning on the Bed Time feature, and ever since then Circle will completely stop responding every couple of days or so, which then requires a router reboot. Whilst in this state, it usually locks out my family members who have a bed time set, but not for other profiles.which don't.
Does anyone have a solution to this?... without having to constantly restart the router?
  • I should have pointed out that I'm on the latest Netgear firmware, and that when Circle stops working, the profiles with a bed time set are not able to access the internet/network during normal hours where they normally would be able to do so (just in case there was any confusion : )
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi JC21,
      I have sent you a message. Please check your inbox.
      Dexter
      Community Team
      • Pmaher's avatar
        Pmaher
        I cannot reconnect, but it was working fine the other day.
