RexAndPhil
Feb 03, 2018Follower
Enable Remote Access Fails - "Incorrect request format, try again."
Hi After a wifi router reset my Netgear Genie App is having issues with Remote Access - Incorrect request format. Prior to the reset, the Genie app was able to remotely access the router. Ge...
DexterJB
Feb 07, 2018NETGEAR Moderator
- HachetaMar 08, 2018TutorI’m having the same issue , this used to worked and I always used it , but all of the sudden it stopped working, can you please address this issue ?
- FiveKidRickMar 17, 2018AspirantI also have the same issue
