ninja661
Jan 29, 2018Luminary
Genie App on Windows 10 FAIL
Wondering if anyone else has had problems with the latest edition of the Genie app for Windows 10? I have tried it, the installer launches but then I get errors about missing DLL files and a whole sl...
MarvinT
Jan 30, 2018Aspirant
I have read with dismay the comments on the problem with the new Genie upgrade because I have experienced the same problem, in fact I cannot get Genie to upgrade itself on downlod it goes nowhere after the MS permissions box has been accepted but also I cannot download the file because I get this error comment.
CODE EXECUTION CANNOT PROCEED BECAUSE
ADVAPIPK___.dll WAS NOT FOUND REINSTALLING the program may fix it
so either this app is corrupted when put on site or there is an error in the code, I think the latter must be the case because surelt the app would have had to be tested before release surely. This makes suggestions and download links to the file useless because the error stated above still occurs. My only hope is some one from Netgera takes this seriously if there are security fixes or we will jjust have to wait for the next release no choice because all other options people have treid here do not work.
Thanks for listening
