ninja661
Mar 12, 2018Luminary
GRUMBLE GRUMBLE @ R8000
Tonight I was looking around my R8000, and as one tv star used to say, "Surprise Surprise Surprise" - I went to the router attached device list and somehow it was all messed up (again!) I have tried...
IrvSp
Mar 13, 2018Master
ninja661wrote:And, ReadyShare vault not detecting external USB drives? This is creating one heck of a headache!!!
I moved my USB drive off the old R7000 without a hitch. Only a 1GB though. Saw my old file structure, but did a PART1 folder only my iPad DLNA client sees? In it is the ROOT? However any other way to look at the share, PC Windows Explorer, FTP, or even the iPad Samba client doesn't see this folder? Odd...
It does seem here that many USB drives can't be seen, and it does possibly depend on the USB drive itself? Some have it working in USB 3.0 but not USB 2.0 for instance. Some have problems possibly due to size (over 4TB's in size generally) and some if it is portable and draw power from the router. My USB is a WD1000H1U 1TB USB 2.0 drive in the 2.0 socket if that matters. I've got a 4TB USB 3.0 drive but I've not tested it on this router.
grumpa43
Mar 19, 2018Apprentice
RE: HDD connected to USB3 & R8000
My experience is this; you cannot power-up or reboot the R8000 with a drive plugged in to the USB3 port - it will not be recognized. So, before power-up / reboot, remove any drive, power up the R8000, and after it has "settled" for a few minutes, plug the drive into the USB3 port and it should be recognized.
- IrvSpMar 19, 2018Master
grumpa43wrote:RE: HDD connected to USB3 & R8000
In my case, after powering it up and inserting the 3.0 flashdrive it did power up (light blinked). It was recognized on the Browser Genie USB ReadyShare tab. But that was as far as it went. I'm on W10 and Explorer could NO LONGER see the router. NET VIEW will not work either. See my post #12 on https://community.netgear.com/t5/Nighthawk-WiFi-Routers/USB-3-0-port-not-working-with-external-HD-on-X6-R8000/td-p/1337978 for details.
- ninja661Mar 20, 2018Luminary
Problem is - if I browsed to the router, I could see the external drive and use it as a FTP server, just the blasted ReadyShare Vault wouldn't even see the drive even though it was connected. I did the manual disconnect of the drive. Unplugged it. Turned off the computer, rebooted the router and then plugged in the drive, reestablished the share points (as the router wouldn't allow me to disconnect the drive until all share points were deactivated) - same result.
