Meo034
Sep 23, 2015Aspirant
Netgear Genie login username
Hi
I recently purchased a Netgear Nighthack R7000 wireless modem and all seems to be working well except the Genie app on my IPad or IPhone. I changed the admin password from the default "password" to a more secure password and since then, I am unable to login using the Genie app. I checked to ensure I have the latest firmware installed on my wireless router (which I do) as well as the latest version of the Genie app. I also have the remote management enabled for the wireless router so that I can monitor the network remotly. However, having the Netgear Genie app would be so much better for my GF and I to manage the network and access to the internet within our household.
Can anyone help me with this issue?
PS: I can remotly connect using the Genie app instead of using the At Home login but as soon as I want to view any of the settings for the R7000 router, it is asking me to enter the admin password. Again, if the default password is set back to the original passwrod, I can access and view/manage my network. However, if I change the passwrod to something different from the default, I am no longer able to login.
Please advise
- DexterJBNETGEAR Moderator
Hi Meo034,
I will need the following information for me to provide you with a recommendation:
1. What version of iOS is the iPhone and iPad using?
2. What version of the NETGEAR Genie is installed on both devices?
3. What is the firmware version of the R7000?
4. Have you tried uninstalling and re-installing the app on both devices?
5. Does the issue happen on other devices (computers, Android devices)?
Dexter
Community Team
- Meo034Aspirant
Hi Dexter
Below are the information requested.
IPhone 6 - IOS 9.01
IPad 2nd Gen - IOS 8.4.1
IPhone - Netgear Genie 2.4.12
IPad - Netgear Genie 2.4.12
I have checked to ensure I have the latest installed and the firmware version V1.0.4.30_1.1.67
I also reset the router multiple times as demanded by NETGEAR in a previous Ticket using their recommended process without any success
I have tried to uninstall and reinstall the Genie app on both devices without any success. I have the exact same results where I can't login to the wireless router using the Netgear Genie app from my IPhone or IPad
The Netgear Genie installed on my laptop (using Windows 7 64-bit) has the same issue once I changed the password within the router to a more robust password other than the default 'passwrod". Once this is done, I can't login from the Netgear Genie app from the laptop. The only way I am able to login into the wireless router is from the web browser using either the 192.168.1.1 or www.routerlogin.net or when the remote management is enabled, then the https:// IP address:8443 However, all Netgear Genie apps will not allow me to login
I do not have an Android device but looking at all the messages, it appears many others have the same issues using Android devices
Please advice on the next possible steps in order to rectify the issue
Regards
Hi Meo034,
Thank you for providing the information. We will need to further isolate the issue since my tests using almost the same setup gave me a different result.
1. Please perform a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps:
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
2. May I know if you have tried another firmware version?
Dexter
Community Team
- MfcloerAspirantI have used the app for months without problems.....until the last app upgrade.
- MfcloerAspirantGenie app will not let me log in with my password or default password. This happened at some point after the last update.
- MfcloerAspirantI found that the latest upgrade requires a minimum 8 characters. I went into router web and reset password to the 8 character minimum and now all back to normal.
- jahSJAspirant
So there is a minimum password length required on the router in order to use the Genie ipad app? I thought my issue might be something like that as the login link was greyed out. Will that be changed to support whatever password the router supports? Thanks, Jeff
