Davidmeronuck
Oct 14, 2016Aspirant
Netgear Genie not working correctly with iOS 10 or Mac Sierra
Netgear Genie App doesnt recognize my R7000 is on the network once I updated to iOS 10.
Also on Mac updated to Sierra, the Netgear Genie app crashes.
In both cases, I have deleted and reinstalled to attempt fix, however they continue to fail.
- Thanks everyone. The updated app took care of the problem for me. Hopefully for all.
- DexterJBNETGEAR Moderator
Hi Davidmeronuck,
Uninstalling then reinstalling the iOS app normally resolves the issue. Have you tried rebooting the router then try logging back in again?
Dexter
Community Team
- Most time I can login with iOS 10 but if I try to go to wireless setup it won't work. iPhone iPad the same
- DavidmeronuckAspirant
Thanks for your responses. I updated the iOS app and it is now working for me. Hopfully that fixes for all. Dave
- I had it tonight working on ios9 updated to 10 won't work
- Glad it worked for you I updated new app last night. I can longin but can't go the wireless settings says something about can't get that info router not resploning.
- Reset modem back to factory default. Restored both iPhone and iPad. I can only login and see map but cannot open to control anything. iOS 9worked good. Do you have app updated
I login I go to upper left box that says wireless I hit that on I get a thing that says netgear router not found or supported make sure not in guest setting an ivp6 not enabled. I have no problem if I use my browser. App is iOS 10
- DavidmeronuckAspirantThanks everyone. The updated app took care of the problem for me. Hopefully for all.
I login then got to hit wireless it gives me previous photo
