jarrodj609
Dec 26, 2015Aspirant
Netgear Genie not working
I see there was a topic that seemed to mirror my issue but it did not seem to be solved.
I have a 6200v2 router.
When I try to use the Netgear Genie I get the following:
- DexterJBNETGEAR Moderator
Hi jarrodj609,
1. What is the version of the NETGEAR Genie program?
2. What is the firmware version of the router?
3. Is this computer wired to the router?
Dexter
Community Team
- jarrodj609Aspirant
Hi Dexter JB,
NETGEAR Genie version 2.4.20
NETGEAR Router Firmware Version V1.0.1.20_1.0.18
Computer is wired to the router.Thanks for the quick reply.
Jarrod
Hi jarrodj609,
I suggest updating the router's firmware to the latest version (1.0.3.10) then reset and reconfigure the router. You may refer to the links below for the steps.
Regards,DexterCommunity Team
