Workingstiff52
Feb 14, 2018Aspirant
New Nighthawk, with a New Genie. New SSDI Button? Nighthawk AC2300 Smart Wifi Router, Model 7000P
First the selection did not give me the model of AC2300 Smart WiFi Router. Which is what I will be talking about. Just purchased, setup went directly to updating software and firmware. It has a new...
- Feb 17, 2018
2nd responce
FOUND IT!!!!I did yet another hard reset of the Router. This time I went through each question and checked the Genie Tree. I was looking at both Negative and Positive responces. Thats where I found the option to Rename and Re-password the existing SSDI.
For anyone looking for help, The Initial Setup Tree ask's the Question, "Can you turn off the existing (in this case Dish) SSDI. I answered "NO". The follow up screen was to change the name of the Netgear SSDI.
WhaLaaAttached is a screenshot of that setup tree screen.
Thanks, michaelnward, for your time, attention and timely return responce.
Moshe
michaelkenward
Feb 16, 2018Guru - Experienced User
Workingstiff52 wrote:
Thank you.
Perhaps I crammed too much into one message.
My problem right now is to create a Specific SSDI on a new Blackhawk. The Genei has been upgraded from the Genie featured in the HELP or YOUTUBE videos. I cannot seem to find the "NEW" button.
You will not find a NEW button for SSIDs.
Nighthawk R7000 routers, like most Netgear routers, are limited to a single SSID for each band 2.4 GHz and 5 GHz. (If you enable Smart Connect both bands share the same SSID.) To create a new SSID you use the desktop genie (or the browser interface) to Modify the default SSID for each channel. The default SSIDs are on the label on the bottom of the R7000. Change them as you see fit.
I have already provided a link to the manual for the R7000. Page 126 explains how to set the SSID.
You can also create a Guest Network for wifi. Read all about this on page 129.
Workingstiff52
Feb 17, 2018Aspirant
2nd responce
FOUND IT!!!!
WhaLaa
Moshe
