Anh28EZ
Dec 03, 2020Aspirant
Nighthaw App stopped working
Hello,
I just noticed that when I enable Circle on the web, I can't login to my Nighthawk App on my phone. I tried to reset the app but it just shows login timeout. It only work again if I disable Circle on the web. Is this normal or I have to do something to get both Circle and Nighthawk apps work together?
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
- Anh28EZAspirant
I'm not sure if this related to Circle or not. I can't find any post related to this.
Why did you mention it twice in your first message then?
You do something to Circle. Your router does strange things.
Seems likely to be connected to me.
