Retired_Member's avatar
Retired_Member
Jul 28, 2021
Nighthawk App Not Working after Firmware Upgrade (Nighthawk MK-83)
I did a manual update of my Router and Satellites with Tech Support. The iPhone app is now useless. The Network Map shows only my Router and two of my three Satellites. When I go to the Device Manager tab, I get an error message - "Could not reach server. Try again later (code: CDIL-API-FAIL)". The app also does not show the number of Connected Devices as it did in the past. The app is also running extremely slow - much slower than before the update. It says "loading" for quite a while before opening any tab.
  • FURRYe38's avatar
    Try a uninstall of the app, reboot mobile device, then re-install app.
    Try a factory reset on the router unit and setup from scratch using a wired PC and web browser, once fully setup, log back in to all and check devices.
    • Retired_Member's avatar
      Retired_Member
      I did uninstall the app, restart my iPhone and then reinstalled the app. Both my iPhone and iPad are still having the same problem.
      I just did a factory reset with Tech Support - after we did that, this problem started. They had no solution. Why would the web app make a difference?
      • FURRYe38's avatar
        Wouls help to get the system setup first using the routers web page, then after its setup, the NH may work after that. If not, NG support will need to pass this to the app team for review.
  • I am having the same issue as others where after the router update, now the nighthawk app does not work. Netgear support and  products are useless pieces of ----. You cannot get any help to resolve the issue. Also netgear routers are widely known for their back door access. Really no privacy or security.
    • michaelkenward's avatar
      michaelkenward
      What about this place?
      I see  no sign that you have tried to get help anywhere else in this community.
      You have joined in on an old discussion about different hardware. (Apps and firmware are linked together.) So it might be worth beginning afresh.
      We'll need a detailed description of your problems and your network before anyone can begin to guess as to what might be going wrong at your end.
      The  R6400 in your footer isn't one of the usual suspects on the troublemaker front. It has been around since 2015 and has had time to bed down.
