Copejack
Sep 21, 2021Guide
Nighthawk App
Can anyone tell me if there is any part of the Nighthawk app that works without issues? It seems like anytime I switch between various features within the app is very unstable. Just get the app to connect to router stinks most of the time. Trying to switch between router and extenders stinks, trying to turn on smart connect stinks, trying to switch from WPA2 to WPA3 stinks. I have not found anything using the Nighthawk app that really works without some kind of connection issue.
I'm not a fan of the nighthawk or the orbi app. Seems like half the time it works, then it gets updated and breaks.
I prefer to just log in through the browser to manage the router/devices.
- CopejackGuideYes, I use a bowser as well and perform some tasks that way as well.
However, from a end user perspective, I expect the Nighthawk app to function properly with minimal issues. Any feature you use inside app works, at best, 50% of the time. It struggles with page switching when using the app.
Has A reset been performed?
- CopejackGuideYes, I have reset the router and extender several times.
I believe that who ever built the Nighthawk app for Iphones, did not do a very good job.
I think it is not a hardware issue with their products, but a software issue with the app.
It is by far the worst app I have ever used.
It seems like regardless of what you are doing inside the app, it struggles with page switching. It struggles to stay connected to router or extender. Most times, it loses connection all together and I can’t even login. I end up closing out the app and restart it again at least 3-4 times before It finally connects to router or extender again.
I'm actually impressed you can open the app. I installed it and it just crashes. Over and over and over. Uninstalled and reinstalled. Same thing. Dozens of reviews of the app on GooglePlay calling it complete junk. I'm seriously considering returning the router.
The latest version of the Android app seems to work on some devices but falls over on others. My Samsung crashes but a Huawei soldiers on.
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
Yes, but I'm not sure why you find that relevent when the discussion is about the app that is garbage.
You're not alone! I have also had these same issues from day 1. When I talked to Netgear, they admitted they have issues with the app. They wanted to upload a firmware for my router that might fix the issues. I declined as it was brand new and I just finished hours or adding all my wifi devices and naming them on my network. Didn't want to start all over again. They told me I could do it later (in the future) but they declined to tell me it was only in the next 20 days! As far as loging in on the web, that also works once in a while for me. Website keeps telling me I need the Nighthawk app installed (yes, even in a Windows Environment) If I knew there was so many KNOWN issues with this app, I would never have bought it! Otherwise, this modem (CAX80) is great!
