uNiTs
Dec 05, 2017Aspirant
NightHawk R6900 Circle app not recognizing
Hello, I activated Circle parental control on R6900 nighthawk router and all was working well. However, now via Android Circle app, i can not connect to manage Circle devices nor does the app recogni...
uNiTs
Dec 06, 2017Aspirant
Problem solved!
Here's the details in case anyone comes looking:
Router version- V1.0.1.28_1.0.21
Circle Android app version- 2.0.6
Did not use another device for problem solving.
As for the solution, I went to my router page and turned off parental controls and hit apply. After the page refreshed I simply turned Circle parental controls back on and hit apply. I know this seems simple enough and it crossed mind to try this. However, I skipped it because I had tried rebooting and figured that was enough.
Looking up the Circle app version for this post I discovered a recent update had been made (December 04). I assume this was the cause.
Thanks
Thanks
