meltyface
Sep 23, 2017Follower
Nighthawk R8000 Parental controls by IP w/out bypass account (pretty big flaw/issue)
Ok, I recently bought the Nighthawk R8000, and I'm pretty dissapointed with what it appears I am unable to do, so please let me know if anyone has a solution for the issue below. I want to restri...
rajis
Sep 25, 2017Guide
If you've successfully enabled Parental Controls on your router, you can set a default level of filtering you'd like and then for kid devices, go into the Network Map, select each device and change the level of filtering for that device specifically.
Hope this helps
